Why full speed Fan and loudly iMac 27 mid 2011
Hi Please I need Help !
long story , I took my Imac to apple care for replacing Video card because the vertical green line conman issue . then after they replace it , it work fine .
problem start when I try to upgrade HDD with New HDD .
I did replace the HDD then I finished reconnected all the cable of LCD. when I turn my Imac I smell something got burned !
I found out the connector (molex ) of the Display Port Power Cable got burned and also one small chip below the connector too .
so I disconnect all the cables of LCD, I did reattach the old Original Apple HDD , I contact my Imac Via TV by HDMI Cable , it work fine bootable I reached my desktop file . ! but the Fan work Loudly and full speed .
- I installed ( HDD Fan Control ) application it show , HDD 1024 PRM , ODD 3234 PRM , this app couldn't solve the problem or control the Fan I tried all option of app Auto, Manual, Smart .
- Idid SMC reset and PRAM reset nothing solve
a) my question first : is there hope to use LCD which option I must go with on this case :
1- got new Display Port Power Cable only !
2- replace the cable + connector (molex) + the small chip
3- replace the logic bored
B) my second question : I can live with Via Monitor rather than using LCD but
how I will solve the problem of full speed loudly fan !
I wonder if the burned chip could effect the logic board .
I did attach Photo on the Link below :
Notice : done SMC reset and PRAM reset nothing solve
Thank you for your time anything will be helpful
Ist dies eine gute Frage?
1 Kommentar
i have the same burnt chip on my motherboard, is it possible to get this fixed?
thanks,
Red
von Red Firth
