Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
iPhone 5 won't charge after battery is fully discharged
The iPhone 5 refuses to charge once the battery is completely discharged. I have changed the battery and the charging port and problem is still there.
When I put a charged battery in, the phone shows that it's charging when plugged in. But again, once it empties to zero, charging it does nothing.
Someone said i should be doing a hard reset. Anyone have any definitive answer please?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
No charging on flat battery or turned off means bad U2 Tristar charging chip.
Get the U2 Tristar Charging IC chip replaced.
It's a component on the logic board that goes bad when the user uses a copy lightning cable / non-certified MFi lightning cable or a car charger.
You will need to find someone that does microsoldering for charging IC on iPhones.
War diese Antwort hilfreich?
Bewertung 5
1 Kommentar:
Thanks. I suspected it was IC related. But it's been very strange. I put a new battery in and after a couple of minutes it started charging. I also updated to iOS 10.2 and during download and install, the phone turned off a couple of times but it finally installed.
I've discharged and recharges a couple of times and seems to be a lot more stable now. See how it goes and thanks for the advice
von
Antwort hinzufügen
Amir A wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 247
