Zum Hauptinhalt wechseln
Polaroid Sun 600 LMS instant camera. Released 1983.
15 Fragen Alle anzeigen
The red light seems to be stuck & doesn't seem to be properly working
I'm aware that I have to half-press on the red button in order to change the flash for my Polaroid.. But the red light will not turn off and change to green, and I have been waiting for several minutes.. What's wrong? It just randomly stopped working and I cannot take another photo until the light turns back to green.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
natjarmay, Both the electronic flash and the camera are powered by the high-energy battery built into
every film pack. Clean the film pack contacts in the camera with a Qtip dampened with 90% Isopropyl alcohol and install new fresh good quality film pack and try the camera.
If this does not solve the problem there could be a problem in the Flash circuitry.
file:///C:/Users/Home/Downloads/600-manual.pdf
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
How would you recommend properly cleaning the film pack contacts?
von
natjarmay , the link below will show how to open th film pack door, with a flashlight you can look inside the compartment and see the copper contacts which should be reachable with long Qtip dampened with 90% Isopropyl alcohol, gently clean the contacts to remove any dust/corrosion/etc., You could also use a can of compressed air to blow out any dust/debri that you see.
Polaroid Sun 600 LMS Film Pack Replacement
von
Antwort hinzufügen
natjarmay wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 86
Insgesamt: 9,905
