Put a iPhone 7 battery in iPhone 6S?
So seeing that the iPhone 7 has a new battery with a bit more power, it made me wonder if you could theoretically mod the 7 battery to work in a 6S?
I mean they both use 4 pin connectors? I would assume iOS could detect a 7 battery and use it correctly(charging , etc) but I don't know for sure.
As for the battery connector, maybe soldering is possible?
Thanks!
Ist dies eine gute Frage?
8 Kommentare
iOS 10 made the iPhone 6s battery crap! As well as iOS 11, I would’ve put my iOS 9 iPhone 6plus battery in my 7 Plus or even 8 plus since it’s bigger and lasts longer! Physically bigger and optimized by the 8 plus , oooooh! Would’ve been amazing! Hopefully it’s software because iPhone 7 Plus battery is worse than the 6 plus! Both software and physically MAH wise
von KyleMile
I put an iphone 7 battery in my iphone 6s successfully too. Had to bend a little the cable connector to fit as described. full capa 2000mAh now! thanks all
von stemcell
How did u bend it exactly because when I bend it the screen doesn’t close due to the cable being raised
von asadali2006
I can’t show the inside of my phone now, but I’ll try to explain: the ribbon must be bent in the form of an S (because it too long). it should be placed at right angle to the lower wall of the housing. In graphic form it looks like this
III - ribbon side view
___ rear wall
/Top view : S /Where ribbon is sitting on the wall
The width of the ribbon should allow the fit. I didn’t have any problem closing the unit. Unless your battery is very fake(?) hope it helps
von Serj
___ rear wall
Top view : S Where ribbon is sitting on the wall
von Serj
3 weitere Kommentare anzeigen
