Zum Hauptinhalt wechseln
Modell A1418 / Ende 2013 / 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
Having a LCD Backlight problem iMac 21.5" late 2013 820-3302-A
Hi techs
One of my costumers brought this iMac for repair, it was working fine while watching NetFlix and then, the screen went dark but voice still working.
I put the light on the LCD and I was able to see the apps, I plugged it to TV screen and it works just fine. Any help with that please?
Is there any fuse or a component for the backlight I need to check ( similar to the filter of iPad mayber ) ???
I've tested the outputs at the logic board feeding the flex cable which goes to the leds and found there's 0 volt on each!!!
Update (02/24/2017)
Ahhhh!
Gotcha
It's FB9708
Many thanks for all
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
7 Kommentare
@iphix what is the 820-XXXX number on your Logic board?
von
oldturkey03
820-3302-A
Thank you
von
Hi dear,
Do you tell us what do you have done? Thanks.
von
Hi there
I have at problem that might be in the same kategory, the screen at my imac 2013 is flickering random, shutting of picture- turning it on after 1/2 second or so.
Turning down brightness(light) is reducing the problem dramaticly.
Sometimes, the screen stay of, an comes first on again when the maskine reboots og goes into st-by.
External screen has no problems, neigher when main screen is constant off.
Anyone have an idea ?
Greetings /Jesper
von
I`d test it with another new LCD this issue must be from LCD not from backlight circuit keep me up to date with your results please.
thank you
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@iphix start by checking the backlight fuse F9700 for continuity. It is a 5A 32V fuse in a 0603 package. If you have conitinuity, then you do want to check it for 12V on either end of the fuse. Black to ground and Red to the contact on the fuse. You do of course need to power up the board.
Update (02/24/2017)
Since you have power on the fuse, use the schematic to check the next components for power. test until you find the component that no longer shows power. Also, do not forget to check the backlight connector J9700
War diese Antwort hilfreich?
Bewertung 6
4 Kommentare:
Thank you
I have got 12.14v on both sides
von
I have 11.76 on both sides of the dude . I have black screen
von
@Justin a question? If everything is measured and it is perfect, what would be the step to follow where would the problem be in the Flex?
because I have the same problem, the iMac 21.5 Late 2013 14.1 starts normally but you can see very little of the image of the apple when it is starting
Now, I did tests with another iMac 21.5 Late 2112 and I get the same problem, the screen is dark, it is impossible for me to believe that something on the Board has been damaged in both iMacs
von
There is a fuse on the logic board of an iMac to manage the backlight
Bewertung 0
1 Kommentar:
where can i buy that fuse
von
Antwort hinzufügen
Justin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 52
Insgesamt: 5,774
