ipad stuck on apple logo
Update (02/26/2017)
when I hold down sleep bottom and home button a slider appears pointing to itunes
Ist dies eine gute Frage?
First suggestion. Plug in the iPad with the lightning cable connected to the wall adapter. Then hold the home and sleep/wake buttons simultaneously for 15-17 seconds until the phone reboots.
This solves a surprising amount of glitches.
War diese Antwort hilfreich?
didn't work I might need to go to recovery mode where do I send it
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 603
Any history on the device? Was it dropped, water damaged, jail broken, etc.
von Gigabit87898
no it wasn't damaged could it be a viris
von nellie55_7
Method 1. Restarting the iPad
1. Press and hold the Sleep/Wake button until the red slider appears.
2. Drag the slider to turn your device completely off.
3. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
Method 2. Hard Reset the iPad
1. Hold down the home and on/off buttons at the same time
2. Continue holding the buttons even after the slider appears on the screen. The screen will eventually go black
3. When the Apple logo appears, let go of the buttons and let the iPad start up like normal.
Method 3. Restoring the iPad
Connect your iPad to your computer and launch iTunes.
Method 4. Use RecoveryTool Fix Recovery to fix iPad stuck on apple logo.
von BillieLourd
