Zum Hauptinhalt wechseln
Der Bose SoundLink Color ist ein Bluetooth-Lautsprecher, der als kostengünstigere und tragbare Alternative zum SoundLink Mini konzipiert wurde.
My Bose Soundlink Colour isn't turning on
I havn't used it for about a month and a half but when I charge it the light, lights up and flickers orange until it is fully charged but after I unplug it i press the power button and it doesn't turn on. Even when it is connected to a power cable it doesn't switch on it just flickers that the speaker is charging. Anyone know how I can fix this?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Can't get my power to come on after trying to hold 15 sec.unplug then plug working when I got it 2 weeks ago now no power help.
von
Einen Kommentar hinzufügen
1 Antwort
Hi, I have the same problem, even if the battery is charged, although for some unknown reason it does tend to self discharge over a couple of weeks.
The only solution I’ve found that always works for me , even if it is fully charged is to attach a charger for a short period of time, a minute is usually enough. If you then disconnect the charger you’ll be able to switch it on, it’s almost as if it goes into some sort of deep sleep mode.
Mine is a version 1 of this speaker, friends who have the SoundLink II don’t seem to experience this problem
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
jeffcamenzuli wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 788
