Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
4 Kommentare
I just replace the ink but can't print because the printer doesn't seem to grab the paper, the paper just went in half way and nothing was print on it.
If you have the HP 1515 can you copy or scan a document OK using the printer's control panel?
If it works OK this way, can you try a test print from the computer that the printer is connected to? (usually found in the Printer properties area in the computer)
4 Kommentare
von adnan abdul ajis
Hi @ adnan abdul ajis,
von jayeff
hey my printer hp 1515 just wont print . i press print from my laptop and nothing happens
von meera ali
hey my printer error, it can scan but its cant prin, and i can open the properties..
von Rikrik Channel
