when I press the gas nothing happens
replaced the battery solenoid valve and voltage regulator still nothing when I press the gas?
Ist dies eine gute Frage?
Here is a link to wiring diagrams: http://www.courtesygolfcars.com/yamaha-s.... They have both the G22A and G22E. Before spending more money on parts, I would take a multimeter and start checking components.
For example, do you get continuity when the key is turned in the key switch, and do you lose continuity when you turn the key off. If so, then there is no need to spend money on the key switch.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,206
mg101474 what make and model is it and what have you checked thus far?
von oldturkey03
Its a 2006 yamaha g22.
I've already replaced the battery voltage regulator and solenoid valve.
Next I'm going to try the accelerator switch and the key switch
von mg101474
I have a g2 1990 that I have the same problem I know there is no spark in the plug
von rey12345
