Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost, bis zu 512 MB DDR5 Video RAM
1539 Fragen Alle anzeigen
Can I use the LCD of a 2009 13-inch on a mid-2012 13-inch MacBook Pro?
Do they have the same connections to the logic board?
Are they exactly the same or was the 2012 one improved?
Thanks in advance
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
LCDs are the same, the lid assemblies are not. The full lid uses a different LCD cable, camera and wifi connection.
If you are going to remove the glass and swap the LCD though, it will work fine.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
Thanks for finding that. I was trying look for it in the repair guide except they aren't loading for me. I have fast wifi and I have a retina with 16 and a 512
von
@sherlock_holmes luckily I don't have to rely on the internet then, since mine is not too great :)
von
lol oh. but u r using the internet to ask the question
von
I'll make that exception to give advice and help someone
von
Thats good plenty good reason
von
Most probably it must fit. But pls do verify connector type at lcd end. If they are same then replacing connector wires will work. Connector end might b different type at other end.
Bewertung 0
Antwort hinzufügen
Alex222 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 80
