Zum Hauptinhalt wechseln
Panasonic released the CF-29 on January 1, 2004. It was designed to survive the harshest environments US Armed Forces, service personnel, and enthusiasts could throw at it. The Black Hawk CF-29 was released in 2009.
17 Fragen Alle anzeigen
Toughbook CF29 Screen Replacement
Is it possible to replace the hole display of a Toughbook CF29 without opening an breaking the seal?
Thx
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I have the replacement part numbers if you need them to your toughbook.
just post the full model number (example: CF-29C3KGZ1M)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I do not think that this is possible. The only way would be to replace the whole top part, however, your cables will have to be disconnected on the inside of the panel. So I guess you will have to split the halves and reseal them after. Personal I think you will do fine with some silicon after as suggested. Good luck
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
lingster wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,184
