Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Bottom half of screen doesn't respond correctly
I have an iPhone 5s that doesn't respond correctly on the bottom half of the screen. It works but when using the keyboard the input is wrong, for instance if I touch F, I might get G or G and F. It is not the digitiser, the screen has been replaced with one that was working perfectly on another 5s so it is something within the phone itself, any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
A few things to consider here:
  • The logical thing to suspect is the screen. If you are confident it is good (can you put it back on the original device it came from to confirm?), then move on to the next item
  • There may be a partial connection only so check the digitizer connector. Also, it should have a little black foam on top of the metal plate on the flex (look at this picture). That allows it to stay firmly connected under the bracket. Don't underestimate the importance of this.
  • You could have a problem on the logic board with the Touch IC. If the phone was bent in the past or dropped often over it's lifetime, this is a possibility. This would require a micro-soldering repair.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I definitely sure it's not the screen. The screen that came with it was the exact same way. So it's going to be one of the other 2. I'll open it up tomorrow and see if I can see what the problem is. Thanks.
von
Antwort hinzufügen
Mary Ellen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 78
