Das Sony Xperia XZ wurde im Oktober 2016 veröffentlicht. Diese Anleitungen zeigen die, wie du ein paar Teile reparieren kannst und die das Telefon funktioniert.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
5 Kommentare:
Hi Ahmed
Need more info please ,
has it been dropped
What lead to this situation
Was it on charge
ect ect
More help you can give the better someone can help
Thanks for the extra info, now it has a high probability of being fixed. But due to the complexity of "the fix" it would be a good idea to take it to a phone shop to do it. Does sound like a full screen replacement needed. I have fixed them before and these ones are not easy. But not impossible, if you want to try it yourself then get onto the tear downs and watch it a couple of times before attempting it. Me, I'm as thick as two short planks and had to watch the teardowns a few times before attempting the repair., but did it
Hi Ahmed
has it been dropped
Was it on charge
ect ect
Regards
Charlie
von Charlie Clemett
It been dropped on the ground and when tried to restart it did not work and then left him on the charge did not give any indication of charging
von Ahmed
Are you under warranty?
von George A.
No i bay it from ather cuntry
von Ahmed
Hi Ahmed
Anyway hope this helps
Charlie
von Charlie Clemett
