Zum Hauptinhalt wechseln
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133 Fragen Alle anzeigen
ZTE Zmax Pro: black screen/glowing home button, won't even vibrate
I have a ZTE Zmax Pro. This is the second phone of this exact model that I've had in the last 4 months, and they both have had the EXACT same flaw. I returned the last one because I thought it was just some manufacturing issue with that particular phone... apparently not.
The phone has randomly decided that it will not unlock or turn on. There is no red light, there is no FTM screen, and there is no android system recovery screen. I can't find anyone with this exact problem anywhere, but it's happened to me twice with two different phones! The screen is completely black aside from the slowly pulsating home button. I've tried charging it regularly, charging it through a computer as suggested, I've tried every single button combination there is, and it won't even so much as vibrate.
I didn't drop it. I keep it far from any moisture. The buttons aren't stuck. The battery was at an 87% charge when the screen went black, and it didn't seem to actually shut down (it looked as though it just locked like normally), so I doubt it's just got a broken charge port like some comments are suggesting.
Please help. I can't afford a third phone. :(
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 41
62 Kommentare
I'm on my 2ndphone in 2 weeks not happy
von
Thank you SO MUCH!!!!!! I was about to freak out as I JUST bout this phone after trouble with my last one. My zte zmax pro just did this same thing and i trued every number of buttons suggested exactly as suggested to reset it and nthing. Then press and hold for 30 seconds worked. Thank the lord
von
Omg the same thing happened to me. Twice. In fact the 2nd time just happened as in posting this from my tablet. The first time it happened I had fallen asleep and had my phone on the floor near me (I fell asleep on the couch lol). I got up and went to check the time and the screen was black but the home button was slowly glowing so I knew it wasnt dead. I tried everything from trying to turn it off to charging it for an hour and got nothing. I took it in and just got this new phone of the exact same model 4 days ago and it just went black while charging. I do not understand why because I havent dropped either phone or got any sort of damage on it whatsoever. Its very frustrating because when I took the first one in, the replacement came in but we received no notification and I didn't have a phone for 12 days.
von
OMG... I have been going crazy for the pass hour. My phone did the exact same thing and I was about to go crazy. I spent 30 minutes trying to google how to fix it. THIS HELPED ME SO MUCH
von
Thank you so much ashleydye26! ...and yes "Praise God!"
von
57 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
14 Antworten
Gewählte Lösung
Hi,
Return this one as well.
It should also be covered by the manufacturer's warranty. Even the remainder of the warranty on the original phone purchase should still be valid, given that you have had both phones no longer than 4 months. Verify the purchase date on the sales receipt or proof of purchase document for the phone to be sure.
If the seller won't help, consult the warranty statement contained in the documentation that came with the phone as to what to do to make a claim for a warranty repair or replacement.
If you can't find it then search online for ZTE ZMax Pro warranty for your country.
War diese Antwort hilfreich?
Bewertung 11
16 Kommentare:
I'm having the same problem, too. I can't afford a second, either. All we have to do is suffer together I guess
von
Hi @beanie,
Is it still covered by the manufacturer's warranty period? If not how far past is it? If it is only over by a month I suggest that you still contact ZTE customer support and express your disappointment in the product failing so soon and politely ask if there is anything that they can do to help. It never hurts to ask. The worst that they can say is no and you will be no worse off.
von
Jayeff, it's questions like these that make warranties useless.
von
Hi @pccheese ,
Why George?
At least with a warranty, you have some recourse in the event of a manufacturing problem.
Can you imagine what it would be like if there were none?
Unfortunately it appears that some countries' consumer protection laws are not as good as others and naturally manufacturers are only going to do as much as they have to, to comply with the legal requirements of the country where their products are available. (not talking about ZTE, just warranties in general)
von
Oops, phrased that wrong. I ment to say that so many people are ignorant of warranties. What's the point of including one if no one knows about them?
von
11 weitere Kommentare anzeigen
Hilfreichste Antwort
So I tried multiple times and this very last time, I held the power button for about 20 - 30 seconds and my phone restarted and is now working properly. So try that if you're still having problems. If that doesn't work then I don't know how to help you. But yeah, hold it for 30 seconds or until it restarts.
Bewertung 54
41 Kommentare:
Thank you!!!!!!l I was just about to give up.
I thought I held it down before for 30 seconds but after reading your comment I tried again and counted slowly. Mini heart attack avoided. My phones only less than 3 months old too. I wonder if the big update, a week ago had caused this issue
von
I'm happy to have helped you! So glad your phone is working again. Come to think of it, it could very much be the update. If it is, hopefully they do another update to fix it.
von
this happen to me as well. thank you.
von
That actually worked on my phone as well!! POS phone, it has been nothing but trouble. This is my second phone and the other one had the same problem. Thanks guys!!
von
Thank you, it worked for me as well.
von
36 weitere Kommentare anzeigen
My mom's phone was having this exact issue. I searched for a solution and found this website but no answers. I finally figured it out, for all those suffering-
PRESS AND HOLD BOTH VOLUME KEYS SIMULTANEOUSLY FOR 20 -30 SECONDS OR UNTIL THE HOME BUTTON STOPS FLASHING AND STAYS LIT. THEN RELEASE AND PRESS THE POWER BUTTON. Your phone should boot up like normal.
Bewertung 11
7 Kommentare:
Yes! That worked! I was beginning to get nervous! Thank you so much!
von
thanks, spent two hours on phone with customer service and nothing, this did the trick, you're awesome!
von
Thanks, this did the trick!!
von
Worked for me. The pulsating home button never stayed lit, but the rate of the pulse slowed down. Pressing the power button on the back then launched the OS
von
This is my daughter's phone I just figured it out her phone went black and I stuck the top of phone reset button with an sharp object, held it 30sec and I pushed the 3rd but on side it will vibrate then come back on
von
2 weitere Kommentare anzeigen
Hey you guys the FREEZER TRICK WORKS, my phone is damaged, screen is cracked everywhere, the screen turns off and doesnt want to display an image every couple weeks I just pop that baby in the freezer for like 5 to 10 minutes, plug it back in to charge, and do the hard power button reset and it is resurrected again like Lazarus!
Bewertung 1
1 Kommentar:
HaHaHa! Like Lazarus!, the way you excitingly explain....So funny! Mine cracked to !&&* too. gonna try
von
Just solved this same problem. The battery is completely dead. I had to use a power bank to provide power fast enough to turn the phone on into recovery. I then wiped the cache and data partitions and factory reset it. It would then start to boot and turn off after a few seconds as if the power button was being held. I was able to get pass this by continuously pressing/releasing the power button. It turns out that there was a short in the power button and would shut the phone off and try to turn it back on immediately, completely draining the battery even with the charger attached. Even with the power bank attached, the phone continued to power cycle, but the power bank provided enough power fast enough to allow the phone to keep cycling until the short resolved. It was probably due to some water getting into the power button after applying a soft screen protector.
Bewertung 0
1 Kommentar:
what do you mean? Do I continuously press the power button whi;e its charging? My phone wont enter recovery mode even with a ppower bank.
von
This is my 2nd phone also and both phones have done this. The 1st one worked holding the volume down and power button at the same time. This phone I had to use the hold all 3 buttons until home button quit blinking then hit the power button. Not the only problem with this phone and wish I never bought it. Now that LG Stylo 3 has 32gig internal memory I will be going that phone. Metro won't replace it again and neither will ZTE.
Bewertung 0
1 Kommentar:
Did you hold downthe power button or just press it once?
von
Had same problem 2 days later picked up phone just tapped power b
Bewertung 0
1 Kommentar:
wait you just pressed the powwr button once? You didn't hold it down or anything?
von
i held down the volume up and volume down and power button....for about 10 seconds. then let go of the volume up button. that got it into FTM mode, from there i just long pressed power button which reset it into normal mode
Bewertung 0
None of these worked at all with my phone. But I kept digging into google and found someone who fixed it. This even works with water damaged devices!! Just put it in the freezer for about 5 minutes. If that doesn't work leave it in for more the ice can't damage your phone. Mine never showed an image before I put it in the freezer. I plugged it in and it said "battery empty, plug in charger for a few minutes, then power on". Just leave it in for 20 to 2 hours and the phone should be working at least for a short period of time. Please comment if this helped you too!
Bewertung 0
1 Kommentar:
@jakob Kenley... your comment is the last on the thread from 2 years ago. I hope you're still in good health. I was losing hope right before i saw your comment.
Because nothing else seem to work. including the whole hard reset thing.. then BOOM here you are with the ice trick. Ofc I thought it was dumb at first, but since I was just gone get a new phone and throw this one out. Why not try it? . while my home screen button was still Glowing. I put mine in the freezing chamber for like 2-5 minutes then took it out. abit scared, When I took it out and pressed the power button, it turned right on!!! But sadly the power button isn't working as of now,well after that one last power on after. . Idk if that's due to me continually pressuring the button through the hard reset process. But thank you so much for Sharing this!
von
Hi this happened to me too all you have to do is hold the power button for ten seconds and it automatically restarts it.i found this out and it worked fine it happened two times and that solution worked, hoped this helped
Bewertung 0
z max pro users:
if you have downloaded the "zedge" app, that might be the problem. shortly after downloading the app, the same issues were happening with my phone (black screen, no light, no turning on, or it went into "ftm" mode, etc.) so, i uninstalled the app and when i turned the phone back on everything was perfect again. its been months and this problem has not happened again. ( i still havent re installed that app either!) youre welcome
Bewertung 0
Bewertung 0
I did as someone else said and just plugged it into a power bank and it came right on
Bewertung 0
Hey guys look I did everything that was mentioned on here except the freezer and I tried and tried and nothing then at the very end I finally connected my phone to a power bank and surprise my phone turned right back on so with that said I honestly think everyone should just plug your phone into a power Bank
Bewertung 0
Antwort hinzufügen
toastedrupees3119 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 106,748
