Zum Hauptinhalt wechseln
9th generation of Chevrolet's full sized SUV, based on the GM GT800 platform.
My speedometer stopped working after the radio was stollen
how to fix speedometer after stereo was stollen
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Matthew Budau , Check all your fuses if all test good, you will have to look under dash and examine all the wires/plugs to see what all got cut, loosened or damaged and make necessary repairs. I hope the links below may also help, wire color codes and schematics. It could also be a problem with stepper motor behind the cluster which may have failed, last link below. Good luck.
http://www.jalopyjournal.com/forum/threa...
http://www.autozone.com/repairguides/Ava...
http://www.bbbind.com/free_tsb.html
http://forums.trailvoy.com/showthread.ph...
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Matthew Budau wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 322
