Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
Coconut Battery says Battery Failure Yes (83) with new battery
I am getting a battery failure #83 with a new battery in coconut, otherwise it's working.
Is the new battery defect and should be changed?
Update (03/16/2017)
here it is
Ist dies eine gute Frage?
Bewertung 5
19 Kommentare:
I have written an email to Chris Sinai (from Coconut-flavor) and requested help from the horses mouth>
von
Thanks, that's kind!
von
Chris never responded, sorry. But I also got in a new battery this week with this same failure. The battery only had 53% of the maximum capacity, weighed about half of what a normal one did. I got my money back and the supplier didn't even want it back.
von
ok, no problem, just did it myself as i was thinking of returning the battery. yours sounds like a rip off. mine was not the cheapest on the market but also not the most expensive, and i am quite satisfied with it. would have returned it back also if it would have been like yours.
von
Thats definitely an aftermarket battery. That means ur battery has 83% of life left with only one load cycle. Usually u should have over 200 cycles on a OEM battery. I would try to get my money back or trade it for a new one
von
14 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
It is just fine. It happens when u get an aftermarket battery.
War diese Antwort hilfreich?
Bewertung 0
8 Kommentare:
@sherlock_holmes ‘It is a capital mistake to theorize before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts.’ -A Scandal in Bohemia
Can you back that statement up?
von
@sherlock_holmes sorry, your answers are partially complete nonsense. i want to point out one of your first answers: "Thats definitely an aftermarket battery. That means ur battery has 83% of life left with only one load cycle. Usually u should have over 200 cycles on a OEM battery. I would try to get my money back or trade it for a new one
16.03.2017 von Lord Vader's Finest Rocketeers " error code 83 has nothing to do with life left. you were mixing up % with codes and so on. please think twice and write nothing before nonsense. nethertheless thanks for your well-mentioned help.
von
What is the designed capacity have? And why was the answers and comments sent to just comments?
von
Is the bottom picture of the old battery?
von
Because there is an error code for that as well. Sorry btw. That was my bad. I don't know what I was thinking
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
heribert weber wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 39
Insgesamt: 5,416
