Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Why is my iPhone 6S won't keep on
After having a water-damaged, I went to the apple service, they cleaned the main board with special liquid, my phone can work again. After a week, my phone suddenly turned off, I charged it two days later and its working. Same thing happened again. I wonder if I should changed the battery because it is 60% when it went off, but it has no power when I try to charge it? I try to plug it in charging right away but it won't turn on, I have to wait at least a day after.
Or is it about the LCD cause the screen went blur before the phone turned off?
Your answer / help would mean so much to me, thank you in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
I'm surprised apple would even offer that. If they did not replace the battery then most likely the battery got affected from the liquid damage.
War diese Antwort hilfreich?
Bewertung 4
Hmm Apple Stores don't do water damage repair in house, they only do basic repairs, or swaps. Was this an Apple Store? Or an independent shop?
Either way, in my experience once you get liquid in the device you are better off using your money towards a replacement, as opposed to trying to get it repaired. Even after you clean a water damaged board it may (and probably will) continue to have issues down the line. You will end up spending more in the long run. Since it is able to boot at the moment I would do a full backup and go through either your insurance, apple directly, or an online vendor to get a replacement
Bewertung 0
Sounds more like the Pmic chip Having contamination under the chip rust will cause many issues.
Bewertung 0
If you aren't expert in testing cables u need to take it to an expert so he can test cables and ic's of ur phone
Bewertung -1
2 Kommentare:
You can't test individual ics on the board without taking the them off so what's the point?
von
there is a way by a flash which is connected at the same time with the motherboard to a computer and it will directly give u where is the problem on the board
von
Antwort hinzufügen
raechalista wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 116
