Zum Hauptinhalt wechseln
Mini flashlight by Maglite that uses a single AAA battery.
Trouble opening ro replace battery
I am trying to open the bottom to replace the battery but it won't budge. Any suggestions?
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
I have this problem too.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
You can try heating the end with a hair dryer, this may help loosen the battery cap. It is possible that the battery has leaked and that is making the flashlight hard to open. The heat trick should help with that. If the battery has leaked, try cleaning the interior with vinegar and some cotton swabs.
War diese Antwort hilfreich?
Bewertung 1
Maybe use some WD-40 and squirt in near it and let it soak down. Have you tried some pliers of grips to remove it?
Bewertung 0
2 Kommentare:
Heat the top battery cap while insulating the bottom then put the bottom into crushed ice using a pot holderto hold thw hot cap then use 2 pair of pliers or grips to open
von
I tried with 2 pairs of vise grips and it won't budge I have no idea what to do.
von
Antwort hinzufügen
sethsmom0618 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 18
Letzte 30 Tage: 72
Insgesamt: 16,057
