Zum Hauptinhalt wechseln
Repair guides and support for the first generation Chevy S-10 (4WD model T-10) Blazer, a mid-size SUV based on the S-10 pickup truck. Closely related to the GMC Jimmy.
Vacuum system for the 4x4 transmission/ transfer case & differential?
Have a 1983 S10 Blazer 4x4 that has vacuum lines on transfer case that are torn loose. Also under the hood is a vacuum diaphragm that leads down to the front differential. It had been disconnected. Need information as to how they are connected & operate.
Thank you for any assistance you can provide.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Here is an AutoZone repair guide for the Differential Carrier. This may point you to your answer.
http://www.autozone.com/repairguides/GM-...
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
James Mixon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,534
