Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Are the displays interchangeable
Hi everybody.
There two MBAs 13", Mid 2012 & mid 2011. One has non working keybord, the other one has a non working display.
I couldnt find an an answer so far, if the displays are interchangeable on those models?!
Even comparing pictures didnt help.
Any ideas? Thx for help.
Kind regards from Krautland
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
1 Antwort
Gewählte Lösung
2010, 2011 and 2012 assemblies are compatible with each other on MBA 13"
War diese Antwort hilfreich?
Bewertung 5
Kommentare:
@reecee: Hello from Krautland & many thanks for your hint. I haven't worked on MBA's so far, so lack of experience. I find it amazing that 3 different models will fit eachother; usually Apple changes tiny bits and pieces within the modelranges, so that e.g. a slightly different socket will throw a spanner in your works.
I will have the chance to check this out by next week & I'll drop you a line.
Kind regards from
Alex deLarge
von
@reecee: Hello from Krautland! I promised to drop you a line! Sorry for being that late, but a very odd flu had kicked into the gutter. All went extremly well! No trouble to interchange the display between the MBA 13 " 2011 & 20112 models. You are a legend in your lunchbox!
Kind regards
Alex deLarge
von
Glad to hear it went well :)
von
Antwort hinzufügen
Alexander deLarge wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 47
