Zum Hauptinhalt wechseln
Why do I have horizontal lines down the screen
I have horizontal lines down the screen,the phone is working fine but the lines are annoying. How and what do I need to do to fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Mine too. But my mobile fell and later after a couple of days, it over heated after a prolonged video meeting, then horizontal lines appears and are irritating
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@nitramet ,Trent, Could be a couple things possibly LCD connection has come loose or LCD has been damaged. I will post a disassembly link below so you can get inside the device and check the connections/clean with Qtip dampened with 90%+ Isopropyl Alcohol and reseat connection and try. If display still bad then it is probably a bad LCD. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=j9SmDB12...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Can u plz tell me how I can fix the lines in My phone
von
How do i get the lines from going down my phone
Update (08/26/2018)
Should I turn the phone off and then turn it back on again
Bewertung 0
1 Kommentar:
I just faced same problem. Any solution you find out yet?
von
Antwort hinzufügen
Trent martin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 5,162
