Zum Hauptinhalt wechseln
Veröffentlicht am 24. Oktober 2011 / 2,2, 2,4, oder 2,5 GHz Quad-Core Intel Core i7 Prozessor
405 Fragen Alle anzeigen
Strange blue lines on my MacBook
Hi,
My MacBook Pro was having problems. Apple reseller diagnosed a broken logic board €1000. I went to an other store and they replaced the video card.
The mac is working but now I'm having this strange issue (this problem started before the mac was fixed)
I'm having blue lines (see pictures)
in different websites (not always, sometimes I can work for hours without any problem) the only thing I can do when this happens is power off the mac with the power button.
Is this a software problem or is there still a hardware problem.
Update (04/06/2017)
On the invoice is noted VGA repair. So not sure it was the graphics card that is changed
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Was it repaired under the program?
MacBook Pro Repair Extension Program for Video Issues
https://www.apple.com/support/macbookpro...
When was it6repaired?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
That looks like the mouse is "selecting" text on the screen, does this only happen on web pages?
War diese Antwort hilfreich?
Bewertung 3
6 Kommentare:
Good Point! I didn't magnify the image (my bad)
That's it! The selection action is engaged. So he has a trackpad problem where the click plate is not correctly set or the ribbon cable is not seated. Or, lastly there was some liquid damage on the trackpad logic.
von
I would remove the trackpad ultrasonically clean it and inspect the ribbon cable and replace if necessary.
von
Okay, but why is the screen stuck when this happens. I need to power down the mac with the power button.
von
If it is in a state of constant "selection" it could be locking up the Mac, just a thought
von
@idoc open this up, disconnect the trackpad, then try and use it with a USB mouse. If you are no longer experiencing this issue, it will be related to the trackpad.
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Mattis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 897
