Zum Hauptinhalt wechseln
Die Honda Fury war der erste Serien-Chopper von Honda, einem großen Motorradhersteller. Ein Chopper ist eine Art Custom-Motorrad, das als extremste aller Custom-Stile gilt und verlängerte Gabeln sowie radikal veränderte Lenkwinkel für einen gestreckten Look verwendet.
Bike missing and dying
Was riding on the Highway when all of a sudden my bike started missing and jerking. Check engine light flashed and it died. Started slowly and ran for about 2 minutes and started missing and died again. What might be the cause?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Connie Toole, Could be fuel issue, bad fuel,filter plugged,pump bad if equipped, gas cap vent hole plugged, etc. or could be ignition/charging system related, fouled plugs/bad wire/ground, faulty coil, weak battery, etc.. Since the engine light did come on there should be an error code that may lead to the issue. Have the computer scanned for codes. Not sure if they can do bikes, but may be worth a shot as some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. If they can not retrieve the codes then you will have to pop into a good local bike shop that can. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
War diese Antwort hilfreich?
Bewertung 5
1 Kommentar:
Stating problem
von Teilen
Stating problems
Bewertung 0
Antwort hinzufügen
Connie Toole wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 47
Insgesamt: 2,056
