Zum Hauptinhalt wechseln
The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
90 Fragen Alle anzeigen
2000 Camry dash mounted A/C-heater fan speeds 1&2 don't work, 3&4 do.
OK... past frustrated on this one...
A good number of years ago, the blower fan that pushes air into the passenger compartment (for A/C and heat) stopped working when the 4-way switch (off, 1, 2, 3, 4) stopped working.
Please, understand, I'm not an idiot when it comes to cars, electrical, electronics, etc. Just that I don't know what it is to look for here.
10 years ago... I started with the obvious... the fuse/relay block in the engine bay. While there are icons for "Fan 1", 2, and 3, I've surmised that these are for the radiator cooling fans.
With speeds 1 and 2 not working, while 3 and 4 still do, I have to think it's a relay/fuse type thing, but with there being 2 distinct "channels" involved. Problem is, I can't determine how to find those "channels".
From what I've read, there's a fan-speed-control RESISTOR, but when it goes out, it seems the fan speed should simply go to "high" (speed 4) and none of the others. I've still got speed 3 working.
So, "relay" is the conclusion.
Or... is it?
The !#^&@* about all this is that I simply like "speed 1", 2 if it's like I've just gotten in the car and need to cool down quickly. But I'm stuck on 3 right now, and it's more air movement than I like, as well as the noise.
Anyone have any thoughts... preferably from experience?
Chip Tredo
Dallas
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Just ordered a new resistor block. Fingers crossed... will post results.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@djtempo ,Chip, Blower motor resistor could be the problem when 1,2 do not work and level 3,4 do work. Also check the plug and wires for the resistor for loose/damage/burnt. The link below may help if you would like to test the resistor plug prior to changing the resistor. 2nd link shows how to replace resistor. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.2carpros.com/questions/toyot...
https://www.youtube.com/watch?v=cHZ2UpcZ...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
@djtempo ,Chip, Good luck with your repair.
von
Antwort hinzufügen
Chip Tredo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 1,288
