Zum Hauptinhalt wechseln
Released on May 1, 2015 by LG. Can also be identified by LS770.
Call Management has stopped
I can make phone calls but when someone calls me it pops up unfortunately call management has stopped? How do i fix this without having to do a factory reset?
Ist dies eine gute Frage?
Bewertung 10
8 Kommentare
unfortunately, the process com.android.phone has stopped
von
I have a LG G3 and I can't find app ATT anywhere not even in my settings what should I do??
von
I'm having a problem wit my style lo 2 phone i can call out but wen i get a call it goes to voice mail
von
I'm having a problem with my LG style 2i cant call out no one can call me its says call manage stoped HEKP PLEASE
von
Facing the same problem but can't find the drivemode on my phone
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
8 Antworten
Hilfreichste Antwort
I had the same issue this morning on my LG Phoenix 3. I called AT&T customer support. The person I spoke with said they had JUST received notification about how to fix the issue... It worked for me:
1. Go to your Apps; Find ATT DriveMode; Uninstall updates
2. In settings, go to Apps, DriveMode, and Disable app.
Hope that helps!
War diese Antwort hilfreich?
Bewertung 19
24 Kommentare:
This fixed my phone! Thank you so much!
von
This worked right away. I find it amusing that AT&T bloatware caused the issue.
von
I wasn't getting any calls this morning... Everything went to voicemail and phone said Call Management has stopped. I followed these instructions "Find DriveMode, Uninstall updates, and disable app" and now I get phone calls fine. This is on an LG K10. This is ridiculous that they would auto install update that makes phone stop receiving phone calls.
von
Thanks, didn't have ATT Drive Mode, but did have Drive Mode in my apps. Force closed, Disabled (Set to factory version? Yes) and now I'm getting calls on my LG X venture
von
Just tried this and so far my phone is ringing again. Ridiculous updates....
von
19 weitere Kommentare anzeigen
Just go to settings-apps and notification-default app-phone app- change to contacts(system).
Bewertung 5
6 Kommentare:
I really appreciate you. Its work me. Thank you so much dear
von
Awesome, it works on my LG V20! Thanks a lot!
von
@Ayodele Segun hello dear am facing the same problem on my LG g5 but I don't know where to locate drive mode on my phone
von
@cheey2003 hi dear am facing the same problem on my LG g5 but I don't know where to find drive mode please help me how did you solve yours
von
@Issah Iddrisu As my LG V20 is not from AT&T, there is no ATT DriveMode app in my phone. The issue happened when TrueCaller app was set as the default Phone app - thus changing it to the stock Contacts (System) app resolved the issue for me.
von
1 weiteren Kommentar anzeigen
Go to the phone app in settings, then select clear cache. If you can, uninstall the app then reinstall it on the play store.
Bewertung 0
6 Kommentare:
i tried that and it didnt work
von
Is there a call management app? If so, do the same.
von
Call apps was my first problem re installed it or first I stopped it then restarted it in safe mode just like screen overlay problem kinda but in safe mode it was hidden elsewhere so I could not find it so I just stopped it in apps I'm trying that outa safe mode then trying in safe mode resetting all app preferences might work if you just keep doing it maybe ?I'll try your way this lg is my first but I'm thinking boost is a pretty sorry server I've been straitalk Trac phone net ten call Trac phone they own them all fixem quickly straitalk lol was losing it at start tried sending signal across ocean no towers poor peps no speak English I called Trac phone boom fixed might think some don't know that because at night your talking Philippines lol they was hired and trained poorly leave you on net lol
von
Quick memo was another bad one on call apps contact trying to reload now voice mail I lost a bunch of time kill and reload is only way or back up till it works heck I have a 32 bit card and 16 gigs on phone kiss it goodbye back up from memory sd it works on mine reinstalling call apps contact it won't let me load any more 1 did but it stinks phone app call log monitor to confusing still said call management stops to might work for you it's a screwy app to figure but I might be not hitting all the tricks yet I'll let you all know k call apps contacts just keeps going out everybtimeb
von
Just disable ATTdrivemode. Worked for almost everyone including me.
von
click on the icon, drag it to the top of the screen, there will be boxes that you can disable and uninstall updates. once doing that your phone will accept calls. hope this helps !
Bewertung 0
1 Kommentar:
Have a lg k8 2017 have no att drive mode at all installed still wont let me call any1 please help
von
I had the same problem. but after uninstalling the True Caller App everything was OK.
Bewertung 0
1 Kommentar:
Wow!!!.. Joseph it works thanks very much
von
For LG v30, …
  • go to settings , then locate apps
  • inside apps, check the burger button tip right ,click to reveal hidden options
  • click on configure apps
  • click on contacts
  • go back one step and click on app permissions , then check contacts
  • done
Bewertung 0
I had de same problem today but after uninstalling truecaller I start receiving calls
Bewertung 0
1 Kommentar:
How do i do the same thing
von
How do i fix my text now to stop saying call management has stop in return it to service
Bewertung 0
2 Kommentare:
I have some problem
von
How do I open my call management
von
Antwort hinzufügen
Katrina Chetney wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 34,737
