Audio divide is not working
Hi Guys, my audio device is not working anymore.
By mistake I inserted 48V from a mixer in the IN input.
My question is: Should I replace the Logical board or I/O Board Cable only?
Ist dies eine gute Frage?
Answering in general:
It depends on what got hit.
It could be a filter or resistor at the gate. It could be the sound controller. It could have gone further.
In my experience, this should be repairable without need for replacing the whole board. Or at least worth a shot by someone who performs board level repair.
If someone here can provide the board number for this model, I may be able to answer you in better details about what may have gone wrong.
War diese Antwort hilfreich?
Check for burnt pins on the I/O cable and check the bottom of the I/O board for burnt components. Most of the time on the Airs, the I/O board will just need replacing, since most of the audio circuit is on here, so do that first.
Hi, thanks a lot for your advice.
I replaced the I/O board and the audio device is working perfectly!
You save me a lot money! :)...
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 70
2 Kommentare
Thank you guys!
I realized that the audio device is not showing as an audio device available in the system preferences.
So I think that the logical board should be replaced.
von Leandro de Faria
If it is showing no speaker available, this is due to the I/O board or the I/O cable, since all of the audio circuit is located on the I/O board, and data is transferred to the logic board by the I/O cable.
Don't replace the logic board, replace the I/O board first if the cable looks fine.
von Reece
