Zum Hauptinhalt wechseln
Die Apple Watch Series 1 ist eine Überarbeitung der ursprünglichen Apple Watch, sie wurde am 7. September 2016 angekündigt. Die meisten Teile sind die gleichen wie bei der Series 2
Apple Watch S1 - Force Touch Gasket Replacement & Adhesive
Is the Force Touch Sensor Gasket (38MM Series 1 Apple watch) from iFixit the only adhesive needed to replace the screen?
The original battery expanded to about twice its normal size and the screen and the force touch sensor gasket were pulled from the watch case in the process.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare
Does your watch still functions normally even with the force touch sensor being broken?
von
Can you tell me what size special screwdriver is needed to remove the touch screen sensor? Thx
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This gets a bit confusing as Apple calls the Original Apple watch Series 1 as well as the 2nd version of it. We on the other hand call the Original and Series 1 (gen2) & 2 as distinctly different versions.
Also keep in mind you're building a bit of a sandwich here between the case and the display: case - adhesive - touch sensor - adhesive - display The touch sensor has one layer of the adhesive you still need the 2nd
So the original watch uses these:
The Series 1 (gen2) & 2
So depending on what got damaged you may need both.
Replace an adhesive strip compatible with the 38 mm case Apple Watch Original model and Series 1 and 2 models. Bild
Produkt
Apple Watch (38 mm) Screen Adhesive
$6.99
Replace the force touch sensor and adhesive gasket that secures the display to the rear case compatible with the 38 mm Apple Watch Original model and Series 1 model A1553 and A1802. Bild
Produkt
Apple Watch (38 mm, Original & Series 1) Force Touch Sensor Adhesive Gasket
$14.99
Replace the force touch sensor and adhesive that fits between the display and rear case of specific models of the Apple Watch. Fits 38mm Series 2 and Series 3 Cellular models. Model numbers A1757, A1816, A1860, A1889, and A1890. Bild
Produkt
Apple Watch (38 mm Series 2 & Series 3 Cellular) Force Touch Sensor Adhesive Gasket
$14.99
Apple Watch Klebstoff Bild
Anleitung
Apple Watch Klebstoff erneuern
Schwierigkeitsgrad:
Mittel
1 - 2 hours
Apple Watch Force Touch Sensor Bild
Anleitung
Apple Watch Force Touch Sensor austauschen
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
War diese Antwort hilfreich?
Bewertung 3
@danj To be completely clear: If you had to replace the Force Touch Gasket, do you need to put one of the adhesive strips under it? The battery fix kit includes two adhesive strips, but the force touch gasket replacement guide sadly doesn't make *any* reference to them (other than listing two of them as required parts).
Taking your sandwich metaphor (which I appreciate, as it’s how I think of this): if I’m replacing the Force Touch Gasket, do I need to have aluminum case -> adhesive strip -> Force Touch Gasket -> adhesive strip -> screen?
I already did a repair using just the FTG, no strips (since the instructions don’t say where to put either one, or when) but of course the FTG alone isn’t holding the screen. Really don’t want to have to do it three times…
Replace a 205 mAh battery compatible with Apple Watch 38 mm Original and Series 1 Models A1553 and A1802. 3.8 Volts (V). Battery Model A1578. Bild
Produkt
Apple Watch (38 mm, Original & Series 1) Battery
$16.99
Bewertung 1
3 Kommentare:
It depends on who made the sandwich ;-}
Assuming you are using new parts, then the gasket would already have at least one surface with the needed adhesive. So at that point you only need one adhesive strip.
von
@danj Thanks for engaging. I'm only drilling down on this because I have already done the repair once and am going to have to do it all over. I think I can do it.. but I want this one to be right.
The iFixit replacement rubber gasket part itself has stickiness on both sides.... just not enough to actually hold the watch closed for more than an hour or so, even after clamping it for 24 hours. It seems to have roughly the same amount of stickiness on both sides (roughly equivalent to a piece of scotch tape).
My concern is I could use an adhesive strip on just the top of the gasket and it could all still pull up from the aluminum. What does your intuition tell you? These seem like the two options:
Aluminum > adhesive strip > gasket > adhesive strip > screen
or
Aluminum > gasket > adhesive strip > screen
Which would you do?
von
@kire2k2 I have the same question. It's not clear if two adhesive strips or one, or if the former, if the same adhesive strip is used for both applications.
von
Antwort hinzufügen
swpenney wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 2,515
