Why does the head spin off when I push the trigger
Everything running perfectly, but now after I fed the lines in as described for replacement, I push the trigger, the head spins and then falls off into 2 pieces. The metal cap (see below that this may be an adapter) that the head screws up to and the head itself.
I screw the head back on ok after I put the cap up first, but it keeps happening.
No idea. Machine has less than 2 hours run time since last 2 years when I bought it.
This area is on the page R diagram. Only thing I can think of is Part 13, the plate adapter on diagram Page K is what is falling off, maybe it is broken due to pounding to get string to run our new length.
This unit had been very unresponsive to touching the head to get new line to fish out.
Ist dies eine gute Frage?
4 Kommentare
Any pictures?
von Javidzed
I tried one more time to tighten it and as mentioned, I guess it was not tight enough even though I appeared to have screwed it all the way. Physics would say not I guess. Ha! It worked ok today, thanks for the answers.
von yahoo.com
alan.yurkovic, That is great that your up and running again, thanks for replying back, good luck with your trimmer.
von L Pfaff
Mine does 1 of 2 two things. 1 is spins off while being used or 2 it will self tighten itself and stop spinning altogether. I've tried various tightening scenarios but neither work. Unit itself hung from my ceiling for 7 yrs as I refused to throw a used1yr machine away. Imagine my surprise as it readily started and runs outstandingly, but my problem remains unfixed. Any insight to why it either spins off or tighten itself and shuts down machine. It a simple nut and head screws on against it. One note, When this 1st occurred could I have missed something falling off with the head that perhaps goes on between the top screw nut and head. Seems the heads spins freely but it will continue regardless where you stop screwing it on to screw itself tightly against the nut above locking the head from spinning.
von Carl Scott
