The phone does not support AT&T LTE.
However, it may be unlocked to support 3g on the 1900mhz frequency.
I would say if you have a Cricket or AT&T store, walk in and simply have them test the phone.
If it does support it, Cricket/Straight Talk/Net10/TracFone will send you SMS that auto configures your phone's APNs.
For AT&T, you may get the same, or you would need to manually put in your APNs, and it would work.
IF not, you would have the extra step on getting the phone unlocked.
However, if only 1900mhz 3g/3.5g is supported, it would not work very well.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
