Zum Hauptinhalt wechseln
Modell A1419 / EMC 2806 / Ende 2014 oder Mitte 2015. 3.3 oder 3.5 GHz Core i5 oder 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 Ende 2015 / 3.3 oder 3.5 GHz Core i5 oder 4.0 GHz Core i7 (iMac17,1) alle mit Retina 5K Displays
571 Fragen Alle anzeigen
M.2 SSD Installation iMac 27 "5K Retina
Hey,
Is it possible to install Samsung 250GB 960 EVO SSD, M.2, NVMe, 3200/1500 MB / s Apple iMac 27 "Retina 5K, late 2014?
Thank you!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
They just don't seem to work very well even with the adapters. I would stay with either an original Apple stick (high dollar) or go with an OWC stick (I don't think they make one yet for this model as they only list these upgrades https://eshop.macsales.com/upgrades/imac...).
It's also very difficult to install: iMac Intel 27" Retina 5K Display Blade SSD ersetzen
Personally I'd add just a standard SSD drive like this: Wie man eine SSD in den 27" iMac (Ende 2015) einbaut
iMac Intel 27" Retina 5K Display Blade SSD Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
2 hours
iMac Intel 27" Retina 5k Display Austausch der SATA HDD gegen eine SATA SSD Bild
Anleitung
Schwierigkeitsgrad:
Mittel
30 minutes - 1 hour
War diese Antwort hilfreich?
Bewertung 4
8 Kommentare:
Hey,
thanks for the answer. What kind of SSD do you recommend to iMac, which would be quick and easy to change?
von
See the last link I gave. As to which drive, it's kind of according to how much storage you need, how readable it needs to be and if you plan on setting up a fusion drive. The fusion drive would be my choice.
von
Thanks for the answer. I have a 1TB Fusion Drive on the Mac but it's very slow? Can Fusion Drive and SSD Partition Separate?
von
First get a handle on how a fusion drive works: http://www.makeuseof.com/tag/what-is-app...
von
Thanks for the information. I read the article. Say your opinion on whether it makes sense to switch to Fusion Drive -> SSD?
Is it possible to distinguish Fusion Drive from SSD, partition etc ..?
Thank you mayer!
von
3 weitere Kommentare anzeigen
I replaced my stick and its not a change at all I get the 1 Terabyte but the speed is about the same just volume gain thats ok. I never had a fusion drive so I did get to put in a 500 G where there was none, thats a gain to and faster than external by just a bit. The NVME is better off on the outside if you have a fusion drive inside its a easy change up.
If there is going to be a Firmware update to stop the bottlenecking on the 15,1 27” iMac then we will see a gain.
Personally I thought the process of putting in a new SSD was very easy I had to add the cable and heat sensor so if I was going all the way I threw in the new stick too. Yes, you're going all the way in, so really if you follow the fix it instructions its easy. I would do it again in a minute. Biggest worries don’t drop the screen.
Bewertung 0
Antwort hinzufügen
Riku wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 8,249
