No orange light when plugged into console
My Xbox One wont turn on and the orange light turns off when I plug the power bar in to the Console
Ist dies eine gute Frage?
Presently working on a psu for xbox. Orange light goes off as soon as box turned on. This supply has a 5v standby supply and a 12v run supply. As soon as the run supply was activated, the ps shuts down. Thats because i found shorted transistors in the primary side of the run supply. This needs a competent technician to repair this. Looks like a surface mount capacitor has had some arcing across its surface. Mosfet defintely shorted.
War diese Antwort hilfreich?
Can you give a bit more detail which transistors you are talking about that were shorted? Is this inside the PSU or the actual Xbox Motherboard?
This guide might help. Clean the brick with caned air when you put back together. Xbox One Netzteil (Day One Edition) Auseinandernehmen
And this guide might help to. Xbox One Hauptplatine austauschen
It sounds like a power issue the board might be shorted out so use a multi meter and check all solder marks and traces. Make sure they all get the right amount of power.
If you have any questions or concerns please comment below or email me at walker44805@gmail.com !
Anleitung
Schwierigkeitsgrad:
Mittel
30 minutes - 1 hour
Anleitung
Schwierigkeitsgrad:
Mittel
30 - 45 minutes
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 8,250
1 Kommentar
Ya i have tried another PowerBrick and all it was doing was flickering orange
von Vimpulse
