Zum Hauptinhalt wechseln
This laptop was released in September of 2010, Identified by model number Inspiron N5030 or Inspiron 15. It is an all black laptop with a DELL logo in the center of the top cover, a mouse pad with separated left and right key buttons, and a disc drive on the right hand side of the computer.
18 Fragen Alle anzeigen
compatability of ram and cpu
I have a dell inspiron 15 N5030 with a Pentium T4500 dual core cpu and just bought 2x 4GB DDR3 1333 (CP3-10600) SODIMM chips for upgrading....I want to upgrade the cpu to the Pentium T9500 core duo cpu and want to know if it will support the same ram chips I bought? thank you very much for your time.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Stephen -
According to Dell support site (http://downloads.dell.com/Manuals/all-pr...) Page 75, the N5030 will support up to 4GB of DDR3-1333, so you should be Ok.
Russ
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
He has 8 Gb of ram that he got. So he wont be ok.
von
Ooops! Thanks.
von
A lot of time, they only test out to 4GB but, I have put in twice that amount and had it work with no problem. It will probably be fine.
von
Russ above said that it supports 4gb but i find that its very possible that it can support 8gb.
Give it a shot. As long as you have a 64 bit version of windows, you should see all 8gb. It wont hurt anything if you do not.
Hope this helps! If it did please hit the accept answer button!
Bewertung 1
thank you everybody for your input....yes I have a current 64 bit windows system....I am currently waiting for that 8GB worth of DDR3 1333 CP3-10600 chips cause I found out the stock t4500 is a 1333 system...am I right in assuming the stronger 9500 would support the same amount? and is it a 1333 cpu also? or more...I can't find the specs anywhere
Bewertung 0
3 Kommentare:
Instead of upgrading the CPU, you would get a better speed kick if you upgraded the hard drive to an SSD.
von
I know ssd drive is way faster than my current hard drive in my dell inspiron 15 N5030 that is running at speed of 5400rpm...I want to know if installing an hdd drive at 7200 will increase my speed more than upgrading the stock t4500 cpu to t9500 at an increase of 2.3ghz to 2.6?
one other factor you should know is that I have the ram maxed at 8gb dual channel and is running at a speed of 6-6-6-15 clocks/latency which I've been told is faster than the chips were designed for
von
Hello Stephen,
Have you got success with upgrading CPU and RAM memory?
von
Antwort hinzufügen
Stephen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 12
Insgesamt: 1,822
