My 2005 c-van all of a sudden has a dead battery
! i jumped it, let it run for about 1/2 . it started fine 3 times ! got up the next morning to go to work and a dead battery !
Ist dies eine gute Frage?
If it has the original battery, you might want to consider a new one. After 12 years it doesn't owe you anything. You can have it tested, usually for free, at many parts stores. They will put a load on it and see if it has the current capacity. You should also put a voltmeter on it and see if you get 12.8 volts or so when the car is running. If not, your alternator needs work.
If you have a newer battery and the alternator is putting out, you probably have something loading it down. Disconnect the terminal and put an ammeter in the line, and see what it is (with the engine off).
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 52
1 Kommentar
pumabuddy clarify what a c-van is. I assume you mean caravan but you know what assuming does....
von oldturkey03
