Zum Hauptinhalt wechseln
Sony ICFC1T alarm clock/radio is manufactured so that in the event of a power outage, you have the peace of mind that your device will continue working so you never miss an event.
12 hour format instead of the 24 hour?
Does this model come with the 12 hour format instead of the 24 hour.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
3 Kommentare
Tough one... The user's manual does state that the radio uses a 12 hour clock, but I read 3 reviews that both stated that the clock uses the 24 hour format.
von
I purchased ICF-C1 from Harvey Melbourne. It cannot change the time format to 24 hrs
von
any one can guide me to change the time format to 12 Hr
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
https://docs.sony.com/release/ICFC1.pdf
That might be of use.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you! Very helpful. I am from the UK and after a little research I found out that the 24 hour format is for UK clocks and the twelve hour ones are for America manufactured clocks. I prefer twelve hour, so I will just order it online from America instead
von
I wouldn't. America uses 120v whereas the UK uses 230v.
Bewertung 0
Antwort hinzufügen
Sam Melrose wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 47
Insgesamt: 11,003
