The handle in the Essential Electronics Toolkit has 3 o-rings on it, there is a very faint chance they could generate/store a charge, but doubtful. The fact the handle is aluminum and there is very little non-grounded surface on the o-rings makes it very safe.
The 64 bit driver kit handle Mako Driver Kit - 64 Precision Bits or [verlinktes Produkt fehlt oder ist deaktiviert: IF145-326-1] for just the handle is ESD safe as it's all metal. (EU store link: https://eustore.ifixit.com/en/Tools/Tool... )
The handle is aluminum, a conductor, and it is not static generating. If you are taking very basic ESD measures (you are grounded to your work with an anti-static wrist strap) then it is very ESD safe. If you are not taking basic ESD measures like grounding yourself to the work environment and device you are working on with a wrist strap "ESD Safe" doesn't matter, any movement you make or tool or item you touch could potentially conduct through you and the driver handle to damage a circuit.
Non-metalic handled tools are different. Some info from the ESD association:
"If you ground a conductor (the conductive metal blade of a screwdriver for example) while it is in the presence of any item carrying electrostatic field (a charged piece of plastic, or clothing) the conductor will acquire an electrostatic charge that may be sufficient to cause damage when discharged. If the handle of that hand tool is sufficiently insulative, and if it does acquire a charge, it will remain on the conductive portion of the tool until it is brought in contact with a ground path, even if the user is wearing a wrist strap. That ground path might be an ESD sensitive component. In this case damage may occur both from initial contact with the charged hand tool and again when the charged component is grounded."
https://www.esda.org/assets/Uploads/docu...
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Is any need to discharge srewing gun during screwing to pcb?
How to make esd ground the electrical screw driver ?
von Amol Pawar
