Touch ID works but home button doesn't
Hello everyone,
recently i changed an iphone 7 screen with a new one. The problem with the new screen is that the touch ID is working but the home button is not. When i "press" the button doesnt do anything. I thought that the flex on the screen it could be faulty. I tried with different screen but the problem stills there. So i decided to put everything back on the old screen which is the original screen. The problem still the same. Does anyone has any idea why this happend? It is very weird. The home button flex is not damaged, i checked it already with microscope. Before of the first changing of the screen the button was working fine.
Thanks in advance.
Ist dies eine gute Frage?
4 Kommentare
Had this issue twice - still unable to solve -
von info
did you get this sorted ? if so help me please
von n0bbys1
Go to Settings -> General -> Accessibility -> AssistiveTouch
Turn on AssistiveTouch and you will see a button show up on the menu. By default, tapping on this button brings up a small menu with a few different buttons. If you go to the “Customize Top Level Menu” option in the AssistievTouch screen, you can get rid of all the buttons except for the home button. Once you do this, the onscreen button becomes a “home” button
von Dennis Chapman
Touch ID is working.
Home button function not working.
I did NOT replace the screen. Only thing replaced, charging port/mic ribbon.
Everything else functions properly. No “clicking” of home, no reaction with taptic, does not exit apps or go to Home Screen.
Touch ID reads properly.
I’ve disassembled phone twice, no change. Tried assistive touch trick, no change.
iPhone 7. Updated to 14.7.1.
von Justin
