Zum Hauptinhalt wechseln
Modell A1312 / Mitte 2011 / 2,7 & 3,1 GHz Core i5 oder 3,4 GHz Core i7 Prozessor, ID iMac12,2
656 Fragen Alle anzeigen
Upgrade CPU iMac 27" early 2011
Are there any restrictions which CPU i could use? Would a i7 4790 work?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
What's your end purpose? What CPU do you have now? Are you trying to speed it up? If so please tell us your RAM configuration and hard drive/s set up and we may be able to give you some suggestions that we've actually tried.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sorry there are limits on what will work. The best you can put in is a 3.4 GHz Core i7 (I7-2600)
The chips are very different TDP & needed socket
As Mayer stated we might be able to offer some guidance on how to make your system run better. Can you tell us what your current CPU, memory & storage is. It would be helpful knowing what you are doing as well.
War diese Antwort hilfreich?
Bewertung 5
Antwort hinzufügen
Zarkex wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 1,400
