Zum Hauptinhalt wechseln
Model A1236 / 4 oder 8 GB Speicherkapazität
132 Fragen Alle anzeigen
Wont charge or turn on at all.
So someone my mom works with gave me a ipod nano 3 to fix. Woulnt turn on, so i replaced the battery. Now it works. But now, when she plugs it in, it is dead. She said i can just keep it as she got another one. What could i try?
UPDATE:
So now this iPod turns on and works, but the battery does not charge at all. It says it is charging but does not. When unplugged it shuts down instantly. What do I do about this.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
@smashederic that fixed it! It came right on and is working now. Thanks!
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Try doing a hard reset. Hold the 'Menu' and center button till the apple logo shows. Hope this helps
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Good to hear it worked @gigabit87898
von
Make sure it is off and take a toothbrush and dip it in rubbing alcohol (I usually wipe in a paper towel before I go any further to make sure it is not soaking wet). Then brush the charging port. Let dry, then plug in and see what happens.
Have you tried a different power cable?
You can also try to factory restore it. Press and hold the menu button and center button and the same time until you see the itunes logo screen. Plug into a computer with iTunes and restore the device - this will ERASE all data on device
Bewertung 1
JoAnnaK is skeptical
Bewertung 0
Antwort hinzufügen
Gigabit87898 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 15
Letzte 30 Tage: 62
Insgesamt: 10,024
