Zum Hauptinhalt wechseln
Why won't my battery charge?
I bought a new charger and I bought a new battery, neither fixed the problem.
I brought it to apple and the guy said it may be the battery cable but I didn't think to ask what else it could be. What else could it be?
I had planned on changing the cable myself but after seeing how elaborate the tear down is I'd like to be more sure that is the problem and maybe not the io board or something else. Is there a way to pinpoint the source of the problem before I start taking it apart, I don't want to have to do it twice.
I changed the hard drive two weeks ago so I think I am handy enough to change whatever I need to fix this.
Thanks for the help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
Guess I'll just start off changing the cheaper battery cable and see what happens from there.
I'll keep you updated.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Most likely
The DC in Board or the battery conector - worst case scenario fault (bad part or broken circuit) on logic board.
Examination by eye might find corrosion or burned spots indicating board failure, the other "shade tree" way is replacing/swapping known functioning parts (work least to most expensive).
Knowing if there's been, or hasn't been, a liquid spill (what liquid and where/when it was spilled can point to more/less likely problems) would be helpful.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Richard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,208
