Das Galaxy S7 Edge ist die Variante mit gekrümmtem Bildschirm von Samsungs 2016 Flaggschiff-Smartphone, dem Galaxy S7. Angekündigt im Februar 2016 und am 11. März 2016 veröffentlicht. Modell SM-G935.
265 Fragen Alle anzeigen
My screen shattered and I need to repair it
the touch and display works fine but the gorilla glass is a mess
i want to know if i can fix it without buying the whole panel?
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Kommentare:
You can, but it'll require a lot of time, patients, and skills to separate the LCD from the touch display. I understand your frustration though. Samsung screen replacements are pretty expensive.
von
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
4 Antworten
Gewählte Lösung
Hi,
Unfortunately, replacing the glass on the s7 Edge is an extremely difficult job, this is due to the AMOLED display being very fragile.
You would need pretty expensive equipment to refurbish the screen to a professional level without breaking it.
It is possible, but also a very hard task.
Most people use heat, from a heat gun, and they use playing cards to slide in under the OCA (optically clear adhesive) due to the cards being thin, and useful for not damaging the screen, this is to separate the glass from the AMOLED panel.
You will usually need LOCA (liquid optically clear adhesive) and a UV lamp to cure the LOCA.
You may need other tools to assist in the repair of the glass, as you'll need to remove the logic board so you don't overheat that, Phillips screwdriver, plastic spudger to disconnect connectors, and you'll need to remove the battery, as lithium ion batteries don't like heat!
Removing the back glass is very simple, heat gun, and you can use a thin spudger to get underneath the glass.
War diese Antwort hilfreich?
Punktzahl 4
Kommentare:
@gedo1992 well this is negative and does not address how to fix it.
von
I know it's pretty negative, but it's quite a reality, it is possible, but will more than likely end up breaking the display, then they have to wait to replace the entire display, I'll slightly edit my answer.
von
Hilfreichste Antwort
Here's how to do it: https://www.youtube.com/watch?v=JEFq1B5v...
Unfortunately it is an expensive part:
https://www.amazon.com/s/ref=nb_sb_noss_...
It might be best to Google this and find a professional who offers the glass replacement service in your area:
"s7 edge glass replacement service"
Punktzahl 4
Frankly speaking you will not be able to do it on yor own as it requires some machines to do it and the amazon is giving the display is very expensive u will get the display around $200
Punktzahl 0
I should take it to a professional i know that but where i am they replace the whole panel and it cost almost 70 percent of the phone around 350 or 400
What do you think repair it or buy a new phone?
Punktzahl 0
Antwort hinzufügen
Adibmardokhy wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 153
