Zum Hauptinhalt wechseln
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
64 Fragen Alle anzeigen
My iBook doesen´t turn on. He make a three "bip". What´s it?
The ibook clamshell doesen´t turn on. I press the button and he makes a signal sound like a short "bip" three times.
I know that mac make sounds to inform that kind of problem is happening. But yhis i don´t know.
Thank´s!!!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
3 beeps at startup means bad RAM or possible bad MLB. Best course of action see if you can find another stick of RAM to test in the machine that matches the specs.
War diese Antwort hilfreich?
Bewertung 4
Replace ram,if it continues replace motherboard
Bewertung 0
1 Kommentar:
i went a bit on the hardcore part on the onboard RAM. I have replaced at first the ram stick, that was a no go, i have replaced the on board rams X4, still a no go. i'm gonna have to say that it is the "Bios" chip that is gone. Not sure which one is the actual Bios "SMC" chip. I do have some spare boards around to fool around and try to pin point the cause of the 3 beeps.
von
Antwort hinzufügen
Maritza wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 28
Insgesamt: 1,312
