Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3978 Fragen Alle anzeigen
Booting up is slow
My iPhone 5S boots up very slowly sometimes.
When on the Apple logo, he stays there for some time. Sometimes he starts up normally, sometimes very slow.
I also noticed that sometimes when on Apple logo he will reboot and start booting again.
Weird, because sometimes everything goes normal, sometimes he starts up slow.
I checked battery health via iBackupBot and battery still have 90% of original capacity.
DFU restore has already been done..
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Antwort
Hilfreichste Antwort
Apple quietly changed the file system in iOS 10.3, it may be that the file system on your iPhone is corrupt.
I would suggest the following:
• backup your iphone completely in iTunes
• grab the latest full iOS update from http://www.iclarified.com/750/where-to-d...
• put your phone into DFU mode
• in iTunes, it will ask to restore -- in Windows hold shift and click Restore and select the firmware you just downloaded; in OS X hold Option and click the restore button and select the firmware you just downloaded
• after the firmware finishes restoring to the iPhone, it will as you to restore from a backup -- don't -- instead, set up as a new iPhone and follow the iphone through the new set up sequence
• now, restore as from the backup you made in the first step.
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
Didn't help. Problem was also there before iOS 10.3.
Thanks though. I apreciate your answer ;)
Sometimes he boots up normally, sometimes he's slow.
von
Just curious, do you have like 100 apps installed, user data / internal storage filled up?
von
Not actually. Even when fresh from regular restor or DFU restore it happens.
von
Antwort hinzufügen
Didier Daniel wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 7
Insgesamt: 758
