Zum Hauptinhalt wechseln
1,4GHz oder 1,6GHz Prozessor, 64 GB oder 128 GB SSD.
User upgradable RAM for 11 Inch MacBook Air
Can I upgrade my 2 GB of RAM on my new (late 2010) 11 inch MacBook Air?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
Hi, According to the included link the ram on your machine can only be upgraded at time of purchase. Sorry.
http://www.everymac.com/systems/apple/ma...
War diese Antwort hilfreich?
Bewertung 4
The SSD is secured by a T5 Torx screw. Do NOT try to unscrew it with a T6 or you will thread it. I almost did that since I read somewhere you need a T6 Torx screwdriver and this is INCORRECT. I bought a T5 since it wasn't in my toolkit and that is indeed the correct one. T5. Make note of this.
Bewertung 1
It looks like they say SSD is not changeable but in reality it is. Maybe the same thing works with ram?
Bewertung 0
The ram is soldered to the motherboard. When you remove the SSD, which is secured with a t6 torx screw you can clearly see the memory modules. The modules are spread out on the actual logic board rather than a removable memory module.
The 2011 model moves the memory to a new location however it is still soldered directly to the logic board and is not removable.
Bewertung 0
yes you can easy
Bewertung 0
Antwort hinzufügen
rickdesigndad wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 19,636
