Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
progres bar stuck at 99%
i have an iphone 6 and restored it with itunes
itunes doesn't show any error completed the restore perfectly
but when the iphone has to complete the restore by itself got stuck in the progres bar in the last pixel wont complete to the end i waited for hours but that one last pixel won't complete
iTunes says that iphone is activated and ready to use
but the screen in the iphone shows just tha progress bar with 99% of the progress bar
i restore it many times still same thing
tried different pc different cambles different IPSW
ios 10.3.2 and ios 10.3.3
if anyone knows if it's hardware issue please let me know
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
Have you try DFU mode ?
von
did you ever figure out
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Try restoring the iPhone using 3UTools
You may have a better chance doing that. If it says clean flash completed then it seems to be stuck at the initial setup boot for some reason.
You can try force turning the phone off and on using home + power button for 10 seconds after clean flash is completed and phone has been stuck on there for 5 minutes.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
i have tried 3utools too but no luck
von
It appears that you have tried alot of things and they didn't help. So this is just a shot in the dark...it has worked for me in the past (I don't know why, but read it somewhere and thought "What do I have to lose")
Heat up your phone a bit...using a hair drier, heat gun or something safe...just to about 80 C or so...while it is hot, try the restore.
I have gotten past this same issue with a couple, as well as Error 1 and a couple others...It's definitely not a "FIX" and wont address the why of what's going on even if it did work... but may get it over the hump to get it going.
Bewertung 2
Try putting your phone into DFU mode. To do that press and hold down both the Power and Home buttons until you see the Apple logo. After it appears, let go of the power button and keep holding down the Home button until you see a screen that says to connect to iTunes. Plug it into your computer and it should say that your phone is in restore mode. Click on Restore and see if that works.
Bewertung 1
1 Kommentar:
thank you for your reply . i have tried even in dfu mode but no luck
von
Antwort hinzufügen
Adrian Zymeri wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 49
Insgesamt: 14,634
