Zum Hauptinhalt wechseln
The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
69 Fragen Alle anzeigen
What is the rocker arm torque on a 1998 dodge dakota.
what is the rocker arm torque on a 1998 dodge dakota
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
ALEX STEVENS, You did not state which engine you have.1998 dodge Rocker Arm Assembly to Cylinder Head torque specs.
2.5L eng. Rocker Arm Assembly to Cylinder Head torque specs. 21ft/lbs., 28NM
3.9L eng. Rocker Arm Assembly to Cylinder Head torque specs 16.67ft/lbs.,22.6NM,
5.2L eng. Rocker Arm Assembly to Cylinder Head torque specs. 21ft/lbs., 28NM
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://dodgeforum.com/forum/2nd-gen-ram...
http://www.torkspec.com/torkspecme.aspx?...
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
ALEX STEVENS wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 3,477
