Zum Hauptinhalt wechseln
A portable, all-in-one, desktop with touchscreen manufactured in 2013 by Dell. Model Number W01A can be found by checking the device's right support foot.
My display setting somehow got changed
I came back to my computer which was just in sleep mode, and the picture is not full screen. There is about two inches on each side that are not used and I can't figure out what I did or if something accidentally got changed. I restarted the computer and looked for any settings but can't figure it out...Help Please!!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Go into device manager and reset your display. Should fix the issue. First, though go into your screen resolution and check to see what the resolution is set as. Sometimes it can be as simple as hdmi cord not connected or vga cord. Unplug then replying back in.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you..thank you..thank you! Somehow the resolution had gotten changed.
von
Antwort hinzufügen
lynn rebbing wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 24
Insgesamt: 272
