Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
The Epson WorkForce 645 is an all-in-one office color inkjet printer. Model: C11CB86201.
40 Fragen Alle anzeigen
display shows scanner error. Turn it off & back on, no results.
Display shows scanner error. Turn it off & back on, no results. Still says scanner error. Can't scan, copy and color printing is terrible. Unable to clean nozzles.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The problem may be that the scanner movement is jammed or the motor is defective. If you can open the scanner section, check the belt that moves the scan head for free movement (do this with power off and power disconnected).
This is a common problem with all in one printers, one device fails and the other devices are not available until the failing device is repaired or replaced.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
how do I open the scanner head, epson expression wf-2520?
von
Antwort hinzufügen
Steve Parmiter wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 4
Insgesamt: 171
