Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Bottom Portion of iPhone 6 is not responsive
Prior to this issue, my Iphone 6's screen was popping outwards because the battery was swelling. I purchased the ifixit kit to replace the battery, and I successful did that. However, I noticed that the bottom portion of my iphone's screen is not responsive. I can click on the apps on the bottom portion, but the very bottom of the screen where the screen ends does not respond. I can't pull up the dock when the phone is vertical. Do I have to purchase a new screen to fix this problem?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The first thing I'd recommend you do is reconnect the digitizer and LCD cables to diagnose the issue. After you've done that, if you're still noticing touch issues the last thing it could be is the screen itself. Touch ic is located on the screen so It may be possible it got damaged in the process. Only other way to diagnose the issue would be to get a new screen and test it.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Yousef Khan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 39
