Panasonic TX-L50ET60E TV horizontal lines / flickering
Hello,
My 3 year old Panasonic TV has started flickering a few days ago.
The lower half of the screen shows horizontal lines (more or less like a 3D display) for a few seconds, then goes back to normal for a few seconds, then shows horizontal lines again, goes back to normal, etc.
The problem occurs whatever source I use (TV, HDMI1, HDM2...). Turning the TV off and on, or a reset to factory defaults didn't help. Firmware is already up to date.
I uploaded a video to show this: https://youtu.be/wn1E-p6PYno
After a few minutes, the display changes to: https://youtu.be/suRb8cLbnjQ
Here are photos after back panel was removed:
Can you please help?
Thank you!
Ist dies eine gute Frage?
13 Kommentare
@vudu horizontal lines are usually an indication of a failed panel. What have you checked thus far?
von oldturkey03
@oldturkey03 thank you for your help!
I haven't tried anything beside what I mentioned in my previous message, as a total newbie :(. I wrote "horizontal lines" but it looks like more or less like interlaced lines (as in 3D display), in case you haven't been able to watch the videos.
I was only thinking about opening the panel and making sure all contacts for cards were not faulty (i.e. loose), if it made any sense (which I'm not sure of).
Thank you
von Olivier
I have a Panasonic as well (TC-L50ET60 from late 2013). Last night it started shifting up and down as yours did but from about 1" from the top of the screen (like your second video). Tonight the whole screen from the 1" down to about 1" up seems to jump back and forth between normal and interlaced mode. Note that this happens on all input, menus and Netflix through the SmartTV menu so it has nothing to do with signals coming in.
Did you figure out the source of your issue? I assume that the display panel is good due to the display being almost fine every couple seconds. I suspect one of the screen drivers are giving a bad signal (although I don't know much about TVs). I haven't opened it up yet to see if there is anything obvious. Anyone have any ideas?
Here's a link to a video of it:
https://youtu.be/5Jl2lu-EsNs
von Troy Mac1ure
Well, I tried replacing the T-Con board but the same issue still persists. I also activated the test mode using the Volume(-) on the main unit and pressing the yellow button on the remote 3 times to display colored screens. These screens also displayed the faint black line at the top.
I assume that this means the issue must be within the panel?
von Troy Mac1ure
Hello,
Thank you all for your answers.
The repair department of the shop where I bought the TV told me it was a failed panel.
I called Panasonic support to ask for a confirmation and they replied with the address of a certified local repair shop. I explained the TV was only 3 years old and asked for some help to pay for the repair quotation but they refused.
I took this as a (polite) way to tell me: 1/ we don't need or want you as a customer 2/ go f* yourself.
I'm planning to buy a Sony, which has never let me down and advise you to do the same.
von Olivier
8 weitere Kommentare anzeigen
