Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Erschienen im April 2016
62 Fragen Alle anzeigen
Why my phone is not getting on after water damage
why my phone is not getting on after water damage
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
1 Antwort
Gewählte Lösung
Sohail Mushtaq, Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide/vid. will enable you to get inside the phone to remove the damage/ corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. Do not mean to give any false hope but after this you will be able to power on the phone and see if further damage has to be addressed. If not wanting to attempt, have a good local cell phone shop have a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=lCgUmu7F...
Electronics Water Damage
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Sohail Mushtaq wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 8
Insgesamt: 720
